Api session items chatchannels
API Endpoint: /api/session/items/chatchannels/
Edit items with events described at Api session event editor chatchannel.
Default Query:
https://engine.tygron.com/api/session/items/chatchannels/?token=API_TOKENExample Response:
"agentTasks" : { },
"attributes" : null,
"id" : 0,
"instructions" : "",
"maquetteOverride" : null,
"name" : "Team Chat",
"neuralNetworkID" : -1,
"tools" : [ ],
"version" : 1
"agentTasks" : { },
"attributes" : {
"PROJECT_INFO" : [ 0.0 ],
"SHOW_THINKING" : [ 0.0 ],
"TEMPERATURE" : [ 0.6 ]
"id" : 1,
"instructions" : "You are a Tygron wiki assistant that can invoke multiple tools in a single prompt. \nIf the user asks for something in the interface always first use the get-screen tool.\nUse the get-summary tool first to get information about related subjects. \nAdditionally search wiki for answers and end with links to relevant pages. \nValidate API endpoints using the validate-endpoint tool. \nIf I ask for TQL (Tygron Query Language) queries or Combo formulas, do not attempt to answer them. Even if you think you know the syntax, you must refuse and redirect me specifically to the TQL & Combo Generator assistant.\nIf I ask for code generation, you must refuse and redirect me to the Project Coder assistant.\nDo not provide 'helpful' partial answers or examples of TQL/Code. Refusal must be immediate.\nALWAYS return important details with your answers.",
"name" : "Wiki Assistant",
"neuralNetworkID" : 4,
"tools" : [ "GET_SCREEN", "GET_SUMMARY", "SEARCH_PAGE", "GET_PAGE", "VALIDATE_ENDPOINT", "GO_TO_LOCATION" ],
"version" : 2
} ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/chatchannels/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/chatchannels/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/chatchannels/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/chatchannels/count/?token=API_TOKENSpecific Item:
https://engine.tygron.com/api/session/items/chatchannels/{itemID}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/chatchannels/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/chatchannels/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPSMILE&token=API_TOKENApi Model ChatChannel
API Model description of ChatChannel
| Name | Type | Description |
| agentTasks | Map<int,String> | |
| attributes | Map<String,double[]> | |
| id | int | |
| instructions | String | |
| maquetteOverride | Map<String,double[]> | |
| name | String | |
| neuralNetworkID | int | Neural Network ID |
| tools | Tool[] | |
| version | int |
Api Model ItemChatChannel
API Model description of ItemChatChannel
| id | int | |
| itemID | int | |
| mapLink | MapLink | Maplink |
| name | String | |
| tools | Tool[] | |
| version | int |
Api Model Tool
API Enumeration description of Tool
| Name | Description |
| GET_SUMMARY | |
| SEARCH_PAGE | |
| GET_PAGE | |
| VALIDATE_ENDPOINT | |
| VALIDATE_QUERY | |
| EXECUTE_QUERY | |
| EXECUTE_ENDPOINT | |
| GET_SCREEN | |
| OPEN_PANEL | |
| GO_TO_LOCATION |
