How to resolve an IP block
Revision as of 12:09, 17 July 2026 by Maxim@tygron.com (talk | contribs)
As part of Tygron Platform’s overall security infrastructure, your accounts and data are protected from unauthorized access by automatically blocking IP addresses that generate excessive failed authentication attempts or otherwise attempt to access the platform illegally. Under some conditions, it is possible inadvertently trigger this protective measure and invoke a temporary IP block.
If this happens, the following steps can offer assistance in resolving the issue.
Try connecting from a different IP
An IP block means any connection from the same origin will be disallowed. To verify that the issue at hand is an IP block, try connecting to the Tygron Platform from a different IP. This can be achieved by using a different network to connect from, such as a home network instead of a company network, a temporary hotspot from a mobile phone, or other such change.
Wait for a couple of minutes
A temporary IP block will last multiple minutes, commensurate with the need to inhibit malicious brute-force log-in attempts. This waiting time cannot be reduced or cancelled. Wait for a few minutes and try again later.
Check for errant connections from the same IP
Other than logging in via the Tygron Client, there are other ways connections can be made to the Tygron Engine, which bear their own authentication requirements. If any such connection is still open but the authentication data is no longer valid, the attempts of that connection to communicate will be counted as failed authentication attempts, possibly (re)triggering a temporary IP block after the waiting time. If after waiting for an extended period the IP block persists, check for any of the following originating from the same IP:
  • Tygron Clients which have been opened for longer than 24 hours
  • Browser windows with 2D viewers or 3D viewers for sessions which are no longer active
  • WFS or WMS connections from the Tygron Engine opened in GIS application for sessions which are no longer active
  • Opened browser windows and/or tabs for Freshdesk or the Tygron Platform API.
  • External scripts, tools, or applications such as FME
Contact Tygron Support
When you are certain that there are no further incorrect authentication attempts from the same IP and the IP block still persists, contact Tygron Support to assist in resolving the issue.
