Api session items terrains
API Endpoint: /api/session/items/terrains/
Default Query:
https://engine.tygron.com/api/session/items/terrains/?f=JSON&token=API_TOKENExample Response:
"current" : {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 657093.832562376, 6800274.005242179 ], [ 657093.832562376, 6799664.916014099 ], [ 658068.3142186847, 6799664.916014099 ], [ 658068.3142186847, 6800274.005242179 ], [ 657093.832562376, 6800274.005242179 ] ] ] ]
"heightValuesCurrent" : null,
"heightValuesMaquette" : null,
"id" : 0,
"maquette" : null,
"name" : "1",
"showSatellite" : true,
"sourceIDs" : [ ],
"typeID" : 9,
"version" : 1
"current" : {
"coordinates" : [ [ [ [ 658068.3142186847, 6800274.005242179 ], [ 658068.3142186847, 6799664.916014099 ], [ 659042.7958749932, 6799664.916014099 ], [ 659042.7958749932, 6800274.005242179 ], [ 658068.3142186847, 6800274.005242179 ] ] ] ]
"id" : 2,
"maquette" : null,
"name" : "3",
"sourceIDs" : [ ],
"typeID" : 9,
"version" : 7
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/terrains/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/terrains/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/terrains/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/terrains/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/terrains-foo/?crs=3857&token=API_TOKENGet Queries
attributes:
https://engine.tygron.com/api/session/items/terrains/attributes/?token=API_TOKENmax version:
https://engine.tygron.com/api/session/items/terrains/version/?token=API_TOKENcount:
https://engine.tygron.com/api/session/items/terrains/count/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/terrains/?f=HTML&token=API_TOKEN&crs=3857JSON:
https://engine.tygron.com/api/session/items/terrains/?f=JSON&token=API_TOKEN&crs=3857GEOJSON:
https://engine.tygron.com/api/session/items/terrains/?f=GEOJSON&token=API_TOKEN&crs=3857GPKG:
https://engine.tygron.com/api/session/items/terrains/?f=GPKG&token=API_TOKEN&crs=3857DXF:
https://engine.tygron.com/api/session/items/terrains/?f=DXF&token=API_TOKEN&crs=3857CSV:
https://engine.tygron.com/api/session/items/terrains/?f=CSV&token=API_TOKEN&crs=3857SSV:
https://engine.tygron.com/api/session/items/terrains/?f=SSV&token=API_TOKEN&crs=3857SMILE:
https://engine.tygron.com/api/session/items/terrains/?f=SMILE&token=API_TOKEN&crs=3857ZIPJSON:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPJSON&token=API_TOKEN&crs=3857ZIPSMILE:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPSMILE&token=API_TOKEN&crs=3857Api Model GeometryCollection
API Model description of GeometryCollection
| Name | Type | Description |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Terrain
API Model description of Terrain
| current | MultiPolygon | MultiPolygon |
| heightValuesCurrent | double[] | |
| heightValuesMaquette | double[] | |
| id | int | |
| maquette | MultiPolygon | MultiPolygon |
| name | String | |
| showSatellite | boolean | |
| sourceIDs | int[] | Sources ID |
| typeID | int | Terrain Type ID |
| version | int |
