Api session items functions
API Endpoint: /api/session/items/functions/
Default Query:
https://engine.tygron.com/api/session/items/functions/?f=JSON&token=API_TOKENExample Response:
"attributes" : {
"DISTURBANCE_DISTANCE_M" : [ 0.0 ],
"OTHER_CONSTRUCTION_COST_M2" : [ 4000.0 ],
"BOWEN_RATIO" : [ 3.0 ],
"NUM_PEDESTRIANS" : [ 0.0 ],
"OTHER_SELL_PRICE_M2" : [ 5000.0 ],
"OTHER_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ 0.0 ],
"SLANTING_ROOF_HEIGHT" : [ 0.0 ],
"ZONING_PERMIT_REQUIRED" : [ 0.0 ],
"NUM_CARS" : [ 0.0 ],
"GROUND_COLOR" : [ -4808597.0 ],
"ALIGN_ELEVATION" : [ 2.0 ],
"NUM_BICYCLES" : [ 0.0 ],
"OTHER_PARKING_LOTS_PER_M2" : [ 0.0 ],
"ROOF_COLOR" : [ -4808597.0 ],
"SEWERED" : [ 0.0 ],
"OTHER_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 0.0 ],
"DRAINAGE" : [ 0.0 ],
"JAM_FACTOR_CARS" : [ 0.0 ],
"TRAFFIC_LANES" : [ 0.0 ],
"LIVABILITY_EFFECT" : [ 0.0 ],
"WATER_MANNING" : [ 0.025 ],
"WATER_STORAGE_M2" : [ 0.0 ],
"MONUMENTAL" : [ 0.0 ],
"NUM_TRUCKS" : [ 0.0 ],
"OTHER_BUYOUT_COST_M2" : [ 4000.0 ],
"NUM_AIRPLANES" : [ 0.0 ],
"GROUND_INFILTRATION_MD" : [ 0.0 ],
"NUM_BUSES" : [ 0.0 ],
"OTHER_UNIT_SIZE_M2" : [ 1.0 ],
"NUM_VANS" : [ 0.0 ],
"SOLID" : [ 0.0 ],
"JAM_FACTOR_VANS" : [ 0.0 ],
"HEIGHT_OFFSET_M" : [ 0.0 ],
"WATER_TRANSPIRATION_FACTOR" : [ 0.0 ],
"CRITICAL_INFRASTRUCTURE" : [ 1.0 ],
"ROOT_DEPTH_M" : [ 0.0 ],
"TRAFFIC_NOISE_SIGMA" : [ 0.0 ],
"TRAFFIC_SPEED" : [ 0.0 ],
"HEAT_EFFECT" : [ -6.0 ],
"VEGETATION_FRACTION" : [ 0.0 ],
"OTHER_HEAT_FLOW_M2_START_YEAR" : [ 0.0 ],
"OTHER_DEMOLISH_COST_M2" : [ 250.0 ],
"OTHER_HEAT_FLOW_M2_START_VALUE" : [ 0.0 ],
"WATER_MICRORELIEF_M" : [ 0.0 ],
"NUM_SHIPS" : [ 0.0 ],
"MAX_FLOORS" : [ 1.0 ],
"OTHER_CATEGORY_WEIGHT" : [ 1.0 ],
"JAM_FACTOR_TRUCKS" : [ 0.0 ],
"NUM_TRAINS" : [ 0.0 ],
"OTHER_PARKING_LOTS_DEMAND_PER_M2" : [ 0.0 ],
"DISTANCE_ZONE_M" : [ 0.0 ],
"TRAFFIC_NOISE_TAU" : [ 0.0 ],
"FOLIAGE_CROWN_FACTOR" : [ 0.0 ],
"BASEMENT_COLOR" : [ -1.1776948E7 ],
"DEFAULT_FLOORS" : [ 1.0 ],
"EXTRA_COLOR" : [ -4808597.0 ],
"SOLAR_PANELS" : [ 0.0 ],
"TOP_COLOR" : [ -4808597.0 ],
"JAM_FACTOR_BUSES" : [ 0.0 ],
"NUM_TRAMS" : [ 0.0 ],
"BASEMENT_HEIGHT_M" : [ 0.0 ],
"PIPES_PERMITTED" : [ 0.0 ],
"FLOOR_HEIGHT_M" : [ 0.0 ],
"TERRAIN_MIX" : [ 0.8 ],
"MIN_FLOORS" : [ 1.0 ],
"SAFETY_DISTANCE_M" : [ 0.0 ]
"categories" : [ "OTHER" ],
"constructionPeriods" : [ ],
"decals" : null,
"defaults" : [ ],
"description" : "An empty plot of land",
"dimension" : -1,
"id" : 0,
"imageName" : "braak.png",
"modelSetID" : 1,
"name" : "Vacant Lot",
"placementType" : "LAND",
"regions" : [ "NORTHWESTERN_EUROPE" ],
"textures" : {
"ROOF" : "sand"
"version" : 7
"attributes" : {
"SLANTING_ROOF_HEIGHT" : [ 2.2 ],
"ZONING_PERMIT_REQUIRED" : [ 1.0 ],
"GROUND_COLOR" : [ -1.0197916E7 ],
"ALIGN_ELEVATION" : [ 0.0 ],
"ROOF_COLOR" : [ -1.0599374E7 ],
"SEWERED" : [ 1.0 ],
"LIVABILITY_EFFECT" : [ -5.0 ],
"WATER_MANNING" : [ 0.013 ],
"SOCIAL_UNIT_SIZE_M2" : [ 80.0 ],
"SOCIAL_PARKING_LOTS_PER_M2" : [ 0.0 ],
"SOLID" : [ 1.0 ],
"SOCIAL_CONSTRUCTION_COST_M2" : [ 2000.0 ],
"HEAT_EFFECT" : [ 5.0 ],
"SOCIAL_SELL_PRICE_M2" : [ 3000.0 ],
"SOCIAL_CATEGORY_WEIGHT" : [ 1.0 ],
"SOCIAL_HEAT_FLOW_M2_CHANGE_PER_YEAR" : [ -1.26E-4 ],
"MAX_FLOORS" : [ 3.0 ],
"SOCIAL_HEAT_FLOW_M2_START_VALUE" : [ -0.315264 ],
"SOCIAL_BUYOUT_COST_M2" : [ 2400.0 ],
"SOCIAL_PARKING_LOTS_DEMAND_PER_M2" : [ 0.029999999329447746 ],
"DEFAULT_FLOORS" : [ 2.0 ],
"EXTRA_COLOR" : [ -1.0197916E7 ],
"SOCIAL_HEAT_POWER_TO_FLOW_MULTIPLIER" : [ 4.86 ],
"TOP_COLOR" : [ -1.0197916E7 ],
"SOCIAL_HEAT_FLOW_M2_START_YEAR" : [ 1900.0 ],
"BASEMENT_HEIGHT_M" : [ 2.0 ],
"FLOOR_HEIGHT_M" : [ 3.2 ],
"SOCIAL_DEMOLISH_COST_M2" : [ 150.0 ],
"categories" : [ "SOCIAL" ],
"constructionPeriods" : [ "POST_WAR" ],
"decals" : {
"ROOF" : [ ],
"EXTRA" : [ 10.0, 0.0, 1.0, 1.98, 2.0, 0.84, 0.0, 2.7, 1.98, 3.7, 0.84, 0.0, 8.2, 1.98, 9.2, 0.84 ],
"TOP" : [ 10.0, 0.0, 1.0, 1.74, 2.0, 0.6, 0.0, 4.5, 1.74, 5.5, 0.6, 0.0, 6.2, 1.74, 7.2, 0.6 ],
"GROUND" : [ 10.0, 1.0, 1.0, 1.98, 2.4, 0.0, 0.0, 3.3, 1.98, 4.3, 0.81, 0.0, 6.8, 1.98, 7.8, 0.81, 0.0, 8.5, 1.98, 9.5, 0.81 ]
"defaults" : [ ],
"description" : "Residential developments designed for low-income housing from the mid-century era",
"dimension" : -1,
"id" : 1,
"imageName" : "huisje7.png",
"modelSetID" : 2,
"name" : "Mid-Century affordable housing",
"textures" : {
"ROOF" : "pane",
"EXTRA" : "bricks",
"TOP" : "bricks",
"GROUND" : "bricks"
"version" : 8
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/functions/?version=100&token=API_TOKENGet Queries
attributes:
https://engine.tygron.com/api/session/items/functions/attributes/?token=API_TOKENmax version:
https://engine.tygron.com/api/session/items/functions/version/?token=API_TOKENcount:
https://engine.tygron.com/api/session/items/functions/count/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/functions/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/functions/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/functions/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/functions/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/functions/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/functions/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/functions/?f=ZIPSMILE&token=API_TOKENApi Model BaseFunction
API Model description of BaseFunction
| Name | Type | Description |
| attributes | Map<String,double[]> | |
| categories | Category[] | Category[] |
| constructionPeriods | ConstructionPeriod[] | |
| decals | Map<FaceType,float[]> | |
| defaults | Type[] | |
| description | String | |
| dimension | int | |
| id | int | |
| imageName | String | |
| modelSetID | int | Model Set ID |
| name | String | |
| placementType | PlacementType | |
| regions | Region[] | |
| textures | Map<FaceType,String> | |
| version | int |
Api Model Category
API Enumeration description of Category
| Name | Description |
| SOCIAL | |
| NORMAL | |
| LUXE | |
| ROAD | |
| PAVED_AREA | |
| EDUCATION | |
| HEALTHCARE | |
| PARK | |
| NATURE | |
| INDUSTRY | |
| OFFICES | |
| OTHER | |
| SENIOR | |
| UNDERGROUND | |
| SHOPPING | |
| AGRICULTURE | |
| LEISURE | |
| STUDENT | |
| GARDEN | |
| INTERSECTION | |
| BRIDGE |
Api Model ConstructionPeriod
API Enumeration description of ConstructionPeriod
| ANCIENT | |
| CLASSIC | |
| PRE_WAR | |
| POST_WAR | |
| CONTEMPORARY | |
| FUTURISTIC |
Api Model DuplicateFunction
API Model description of DuplicateFunction
| id | int | |
| orginalFunctionID | int | Function ID |
| version | int |
Api Model FaceType
API Enumeration description of FaceType
| BASEMENT | |
| GROUND | |
| EXTRA | |
| TOP | |
| ROOF |
Api Model Function
API Model description of Function
| id | int | |
| version | int |
Api Model PlacementType
API Enumeration description of PlacementType
| WATER | |
| LAND | |
| HYBRID |
Api Model Region
API Enumeration description of Region
| NORTH_AMERICA | |
| NORTHWESTERN_EUROPE | |
| ASIA | |
| AFRICA | |
| OTHER |
Api Model Type (Stakeholder)
API Enumeration description of Type
| CIVILIAN | |
| COMPANY | |
| EDUCATION | |
| EXPERT | |
| FARMER | |
| HEALTHCARE | |
| HOUSING_CORPORATION | |
| MUNICIPALITY | |
| MEDIA | |
| PROJECT_DEVELOPER | |
| UTILITY_CORPORATION | |
| WATER_AUTHORITY | |
| OTHER_AUTHORITY | |
| OTHER |
