Api session event editor overlay remove overlay function
Revision as of 07:05, 14 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/remove_overlay_function/
Description: Remove a highlighted Function from a specified Function_HIGHLIGHT Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a Function_HIGHLIGHT Overlay)
1 REQUIRED (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) Function IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_overlay_function/", options)
