How to start the editor with an Empty Project
Revision as of 14:06, 13 July 2026 by Frank@tygron.nl (talk | contribs)
Main menu → Editor → New Project
In some situations it might be desired to generate a project that is not based on real data. For instance when a project needs to be created around a fictional area, or when a project only needs to be created to quickly place and view a Building. In such a case it is possible to select in the wizard the option to generate a project not based on real data. The result will be a project without any Buildings and with a default grassland terrain. These will need to be added manually, in the editor.
How to generate a project not based on real data:
  1. Log in to the online Tygron Platform
  2. Select "New Project"
  3. Name the project as desired
  4. Select localization settings and continue
  5. Select the option "No" when asked to use real data and continue
  6. Set the size of the area to be generated and continue
  7. Select Generate Map
  8. Notice in the 3D Visualization that an empty map was generated
