Web water
Revision as of 10:01, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Base URL: web/water
GET txt
API Endpoint: web/water.txt
Parameters:
Name Location Type Default value
format Path String
id Query Integer
maptype Query Map Type MAQUETTE
width Query int 256
height Query int 256
offset Query float 0
flipY Query boolean false
worlddatum Query boolean false
decimation Query int 16
Examples
Query Water instead of Terrain elevation:
https://engine.tygron.com/web/water.txt?token=WEB_TOKEN
GET bin
API Endpoint: web/water.bin
Parameters:
format Path String
id Query Integer
width Query int 256
Examples
https://engine.tygron.com/web/water.bin?token=WEB_TOKEN
