Api session event participant net cluster set load attributes
API Endpoint: api/session/event/participant/net_cluster_set_load_attributes/
Description: For each Net Load of a Net Cluster, set the value of the Attributes.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Initiating Stakeholder ID | |
| 1 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster ID | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute names | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Value arrays |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Attribute name 1", [ 1.0, 2.0 ] ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'JavaScript example POST
body: '[ 1, 1, "Attribute name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/participant/net_cluster_set_load_attributes/", options)
