Api session event participant measure cancel construction
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/measure_cancel_construction/
Description: Cancel a Measure planned by a Stakeholder while in pre-construction phase.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MEASURE Integer ID) Measure ID
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/measure_cancel_construction/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/measure_cancel_construction/", options)
