Api session event logic money transfers set approved
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/money_transfers_set_approved/
Description: Approve a Money Transfer.
0 REQUIRED (MONEY_TRANSFER Integer ID) Money Transfer ID
1 REQUIRED (true, false) Approved true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/money_transfers_set_approved/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/money_transfers_set_approved/", options)
