Api session event answer measure construction approval
Revision as of 10:00, 13 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/measure_construction_approval/
Description: Stakeholder approves the construction of a Measure.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MEASURE Integer ID) Measure ID
2 REQUIRED (STAKEHOLDER Integer ID) Approving Stakeholder ID
3 REQUIRED (true, false) Approves true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/measure_construction_approval/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_construction_approval/", options)
