How to import a 3D model in ArcGIS Pro
With the Import 3D Files tool in ArcGIS Pro, the following file formats can be imported:
- OBJ (Wavefront object) Used in most 3D animation packages like Autodesk 3dsmax and Maya.
- DAE (Collada) Used in most 3D animation packages like Autodesk 3dsmax and Maya.
- 3DS (3D studio) Used as an exported file from Autodesk 3dsmax.
- FLT (OpenFlight) Used in MultiGen Creator.
- WRL (Virtual Reality Modeling Language File) A VRML file format for representing 3D vector graphics.
See the steps below:
How to import 3D files in ArcGIS Pro:
- In ArcGIS Pro go to the "Analysis" Tab and select "Tools"
- On the right pane select the "Import 3D Files" tool or type it in the search bar to find it
- In the "Input files" field click on the folder icon next to the field and browse to the 3D file(s) you want to import
- A name will be automatically generated in the "Output Multipatch Feature Class" field.
- Select a Coordinate system from the dropdown menu or by clicking on the grid sphere icon next to the field
- Only select "Y is Up" if your 3D model was exported from a package which uses Y is up.
- Click on "Run" at the lower right of the pane
- Once complete, locate the new multipatch feature in the Contents pane, right-click it, and select Properties.
- Select the Elevation tab and select On the ground and then Ok to place the model on the surface terrain.
Step 1
Step 2
Step 3a
Step 3b
Step 4
Step 5
Step 6
Step 9
| <<Back to SLPK manual |
