Api session items chatchannels
Revision as of 07:14, 7 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/chatchannels/
Edit items with events described at Api session event editor chatchannel.
Default Query:
https://engine.tygron.com/api/session/items/chatchannels/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : null,
  "id" : 0,
  "instructions" : "",
  "maquetteOverride" : null,
  "name" : "Team Chat",
  "neuralNetworkID" : -1,
  "tools" : [ ],
  "version" : 1
  "attributes" : {
    "PROJECT_INFO" : [ 0.0 ],
    "SHOW_THINKING" : [ 0.0 ],
    "TEMPERATURE" : [ 0.7 ]
  "id" : 1,
  "instructions" : "You are a Tygron wiki assistant that can invoke multiple tools in a single prompt. \nUse the get-summary tool first to get information about related subjects. \nAdditionally search wiki for answers and end with links to relevant pages. \nValidate API endpoints using the validate-endpoint tool. \nFor questions related to TQL, Combo overlays refer to the TQL & Combo Generator assistant. \nALWAYS return important details with your answers.",
  "name" : "Wiki Assistant",
  "neuralNetworkID" : 4,
  "tools" : [ "GET_SUMMARY", "SEARCH_PAGE", "GET_PAGE", "VALIDATE_ENDPOINT" ],
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/chatchannels/?version=100&token=API_TOKEN
Get Queries
attributes:
https://engine.tygron.com/api/session/items/chatchannels/attributes/?token=API_TOKEN
max version:
https://engine.tygron.com/api/session/items/chatchannels/version/?token=API_TOKEN
count:
https://engine.tygron.com/api/session/items/chatchannels/count/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/chatchannels/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPSMILE&token=API_TOKEN
Api Model ChatChannel
API Model description of ChatChannel
Name Type Description
attributes Map<String,double[]>
id int
instructions String
maquetteOverride Map<String,double[]>
name String
neuralNetworkID int Neural Network ID
tools Tool[]
version int
Api Model Tool
API Enumeration description of Tool
Name Description
GET_SUMMARY
SEARCH_PAGE
GET_PAGE
VALIDATE_ENDPOINT
VALIDATE_QUERY
EXECUTE_QUERY
EXECUTE_ENDPOINT
