Api session event editor chatchannel set neural network
Revision as of 14:37, 6 July 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorchatchannel/set_neural_network/ Description: Set the LLM Neural Network for the Channel. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Chat Channels | |- | 1 | REQUIRED | (NEURAL_NETWORK Integer ID or multiple integer values in array [1, 2, 3]) | LLM Neural Networks | |} ===Response Codes=== {|class=wikitabl...")
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
1 REQUIRED (NEURAL_NETWORK Integer ID or multiple integer values in array [1, 2, 3]) LLM Neural Networks
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/set_neural_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/set_neural_network/", options)
