Api session items netsettings
Revision as of 07:44, 22 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netsettings/
Edit items with events described at Api session event editor netsetting.
Default Query:
https://engine.tygron.com/api/session/items/netsettings/?f=JSON&token=API_TOKEN
Example Response:
  "id" : 0,
  "value" : "1.0",
  "version" : 1
  "id" : 1,
  "value" : "true",
  "version" : 5
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/netsettings/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/netsettings/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/netsettings/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netsettings/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/netsettings/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netsettings/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netsettings/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netsettings/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netsettings/?f=ZIPSMILE&token=API_TOKEN
Api Model NetSetting
API Model description of NetSetting
Name Type Description
id int
value String
version int
