Api session items geolinks
Revision as of 13:04, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/geolinks/
Edit items with events described at Api session event editor geolink.
Default Query:
https://engine.tygron.com/api/session/items/geolinks/?f=JSON&token=API_TOKEN
Example Response:
  "functionID" : 0,
  "id" : 0,
  "priority" : 55,
  "tree" : false,
  "version" : 1
  "defaultWidth" : 10.0,
  "elementType" : "MULTIPOLYGON",
  "functionID" : 747,
  "id" : 1,
  "priority" : 0,
  "subTypes" : {
    "BUILDINGS" : [ ]
  "tree" : false,
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/geolinks/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/geolinks/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/geolinks/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/geolinks/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/geolinks/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/geolinks/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/geolinks/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/geolinks/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/geolinks/?f=ZIPSMILE&token=API_TOKEN
API Model description of AreaGeoLink
Name Type Description
additionals Map<String,double[]>
geomMode GeometryMode
id int
lineBuffer double
mappings Map<String,String>
matchings Map<String,java.lang.String[]>
name String
pointBuffer double
priority int
version int
Api Model BGTAppearance
API Enumeration description of BGTAppearance
Name Description
TEGELS
KLINKERS
BETON_STENEN
BETON_ELEMENT
ASFALT
ZAND
ONBEKEND
Api Model BGTFunction
API Enumeration description of BGTFunction
Name Description
VLIEG_BAAN
FIETSPAD
INRIT
OV_BAAN
OVERWEG
PARKEERVLAK
AUTOSNEL_WEG
AUTO_WEG
LOKALE_WEG
REGIONALE_WEG
RUITERPAD
SPOORBAAN
VOETGANGERSGEBIED
VOETPAD_OP_TRAP
VOETPAD
WOONERF
ONBEKEND
API Model description of BGTFunctionLink
categories Category[] Category[]
className String
functionID int Function ID
id int
layer BGTLayer
priority int
transmissionTowerFoundations int
tree boolean
typeName String
version int
Api Model BGTLayer
API Enumeration description of BGTLayer
Name Description
BAK
BEGROEIDTERREINDEEL
BORD
BUURT
FUNCTIONEELGEBIED
GEBOUWINSTALLATIE
INSTALLATIE
KAST
KUNSTWERKDEEL
MAST
ONBEGROEIDTERREINDEEL
ONDERSTEUNENDWATERDEEL
ONDERSTEUNENDWEGDEEL
ONGECLASSIFICEERDOBJECT
OPENBARERUIMTE
OPENBARERUIMTELABEL
OVERBRUGGINGSDEEL
OVERIGBOUWWERK
OVERIGESCHEIDING
PAAL
PUBLIC
PAND
PLAATSBEPALINGSPUNT
PUT
SCHEIDING
SENSOR
SPOOR
STRAATMEUBILAIR
TUNNELDEEL
VEGETATIEOBJECT
WATERDEEL
WATERINRICHTINGSELEMENT
WEGDEEL
WEGINRICHTINGSELEMENT
WIJK
Api Model BGTMaterial
API Enumeration description of BGTMaterial
Name Description
CLOSED
HALF
OPEN
UNKNOWN
API Model description of BGTRoadLink
appearance BGTAppearance
function BGTFunction
id int
material BGTMaterial
priority int
tree boolean
version int
API Model description of BGTTerrainLink
className String
id int
layer BGTLayer
priority int
terrainTypeID int Terrain Type ID
typeName String
version int
API Model description of BRPLink
cropCodes int[]
description String
id int
priority int
tree boolean
version int
API Model description of BagBuildingLink
id int
priority int
residenceType ResidenceType ResidenceType
tree boolean
version int
API Model description of BuildingAttributeGeoLink
attribute String
featureAttributes Map<String,java.util.List<java.lang.String>>
id int
priority int
value double
version int
API Model description of BuildingGeoLink
id int
lineBuffer double
name String
pointBuffer double
priority int
version int
Api Model Category
API Enumeration description of Category
Name Description
SOCIAL
NORMAL
LUXE
ROAD
PAVED_AREA
EDUCATION
HEALTHCARE
PARK
NATURE
INDUSTRY
OFFICES
OTHER
SENIOR
UNDERGROUND
SHOPPING
AGRICULTURE
LEISURE
STUDENT
GARDEN
INTERSECTION
BRIDGE
API Model description of CustomFunctionGeoLink
id int
lineBuffer double
name String
pointBuffer double
priority int
version int
API Model description of CustomGeoLink
id int
lineBuffer double
name String
pointBuffer double
priority int
version int
API Model description of FGRTerrainLink
fgrName String
id int
priority int
version int
API Model description of FunctionChangeGeoLink
add boolean
category Category Category
id int
priority int
tree boolean
update boolean
version int
API Model description of FunctionGeoLink
id int
priority int
tree boolean
version int
Api Model GeoElementType
API Enumeration description of GeoElementType
Name Description
POINT
LINESTRING
MULTIPOLYGON
API Model description of GeoLink
id int
priority int
version int
Api Model GeometryMode
API Enumeration description of GeometryMode
Name Description
NORMAL
RADIUS_CENTERPOINT
API Model description of IMWABuildingLink
aquoName String
bufferWidth double
id int
priority int
tree boolean
type IMWAType
version int
Api Model IMWAType
API Enumeration description of IMWAType
Name Description
CULVERTS
API Model description of OSMFunctionGeoLink
defaultWidth double
elementType GeoElementType
id int
priority int
subTypes Map<OSMLayer,java.util.List<java.lang.String>>
tree boolean
version int
Api Model OSMLayer
API Enumeration description of OSMLayer
Name Description
AERIALWAY
AEROWAY
AMENITY
BARRIER
BOUNDARY
BUILDINGS
CONSTRUCTION
CRAFT
EMERGENCY
GEOLOGICAL
ROADS
HISTORIC
LANDUSE
LEISURE
MAN_MADE
MILITARY
NATURAL
OFFICE
PLACES
POWER
PUBLIC_TRANSPORT
RAILWAYS
ROUTE
SHOP
SPORT
TOURISM
TUNNEL
WATERWAYS
BRIDGES
API Model description of OSMTerrainGeoLink
defaultWidth double
id int
priority int
version int
Api Model ResidenceType (BagBuildingLink)
API Enumeration description of ResidenceType
Name Description
MOORAGE
STAND
API Model description of RoadGeoLink
id int
lineBuffer double
name String
pointBuffer double
priority int
version int
API Model description of StreetObjectGeoLink
id int
lineBuffer double
name String
pointBuffer double
priority int
version int
Api Model TNLBuildingHeightType
API Enumeration description of TNLBuildingHeightType
Name Description
LAAGBOUW
HOOGBOUW
ONBEKEND
API Model description of TNLBuildingLink
buildingTypes TNLBuildingType[]
heightTypes TNLBuildingHeightType[]
id int
priority int
slantingRoofHeight double
tree boolean
version int
Api Model TNLBuildingType
API Enumeration description of TNLBuildingType
Name Description
BRANDTOREN
BEZOEKERSCENTRUM
BUNKER
CREMATORIUM
DEELRAADSECRETARIE
DOK
ELEKTRICITEITSCENTRALE
FABRIEK
FORT
GASCOMPRESSIESTATION
GEMAAL
GEMEENTEHUIS
GEVANGENIS
GRENSKANTOOR
HOTEL
HUIZENBLOK
HULPSECRETARIE
KAPEL
KAS_WARENHUIS
KASTEEL
KERK
KERNCENTRALE
KLOKKENTOREN
KLOOSTER
KLINIEK
KUNSTIJSBAAN
KOELTOREN
KOEPEL
LICHTTOREN
LUCHTWACHTTOREN
MANEGE
METROSTATION
MILITAIR_GEBOUW
MOTEL
MUSEUM
PARKEERGELEGENHEID
PEILMEETSTATION
POLITIE_BUREAU
POMPSTATION
POSTKANTOOR
PSYCHIATRISCH_ZIEKENHUIS
RADARPOST
RADARTOREN
RADIOTOREN
RECREATIECENTRUM
REDDINGBOOTHUISJE
REDDINGHUISJE
RELIGIEUS_GEBOUW
REMISE
RUINE
SCHAAPSKOOI
SCHOOL
SCHOORSTEEN
SPORTHAL
STADION
STADSKANTOOR
TANK
TANKSTATION
TELECOMMUNICATIETOREN
TOREN
TRANSFORMATORSTATION
TREINSTATION
UITZICHTTOREN
UNIVERSITEIT
VEILING
VERKEERSTOREN
WATERRADMOLEN
WATERTOREN
WEGENWACHTSTATION
WEGRESTAURANT
WERF
WINDMOLEN
WATERMOLEN
KORENMOLEN
WINDTURBINE
ZENDTOREN
ZIEKENHUIS
ZWEMBAD
OVERIG
API Model description of TNLFunctionTerrainLink
id int
landUses TNLTerrainLandUse[]
mustContainHouses boolean
priority int
tree boolean
version int
Api Model TNLHoofdafwatering
API Enumeration description of TNLHoofdafwatering
Name Description
JA
NEE
API Model description of TNLRailLink
id int
priority int
railTypes TNLRailType[]
tree boolean
version int
Api Model TNLRailType
API Enumeration description of TNLRailType
Name Description
TREIN
METRO
TRAM
GEMENGD
SNELTRAM
Api Model TNLRoadHardnessType
API Enumeration description of TNLRoadHardnessType
Name Description
HALFVERHARD
ONVERHARD
VERHARD
ONBEKEND
API Model description of TNLRoadLink
hardnessType TNLRoadHardnessType[]
id int
priority int
roadType TNLRoadType[]
tree boolean
usageType TNLRoadUsageType[]
version int
Api Model TNLRoadType
API Enumeration description of TNLRoadType
Name Description
AUTOSNELWEG
HOOFDWEG
REGIONALE_WEG
ROLBAAN
PLATFORM
STARTBAAN
LANDINGSBAAN
LOKALE_WEG
STRAAT
ONBEKEND
OVERIG
Api Model TNLRoadUsageType
API Enumeration description of TNLRoadUsageType
Name Description
SNELVERKEER
VLIEGVERKEER
BUSVERKEER
FIETSERS
PARKEREN
PARKEREN_CARPOOL
PARKEREN_PR
RUITERS
VOETGANGERS
ONBEKEND
OVERIG
API Model description of TNLStreetObjectLink
id int
objectTypes TNLStreetObjectType[]
priority int
tree boolean
version int
Api Model TNLStreetObjectType
API Enumeration description of TNLStreetObjectType
Name Description
PAAL
PAALWERK
METROSTATION
MUUR
OLIEPOMPINSTALLATIE
RADIOBAKEN
RD_PUNT
RADIOTELESCOOP
PEILSCHAAL
PIJLER
PLAATSNAAMBORD
HUNEBED
KAAP
KABELBAAN
KABELBAANMAST
HEG_HAAG
HEKWERK
HELIKOPTERLANDINGSPLATFORM
HOOGSPANNINGSLEIDING
HOOGSPANNINGSMAST
KRAAN
KRUIS
KOGELVANGER_SCHIETBAAN
LUCHTVAARTLICHT
LEIDING
MARKANT_OBJECT
KILOMETERPAAL
KILOMETERPAAL_SPOORWEG
KILOMETERRAAIPAAL
KILOMETERPAAL_WATER
KILOMETERRAAIBORD
KOEDAM
DUKDALF
BUSSTATION
CALAMITEITENDOORGANG
GOLFMEETPAAL
GRENSPUNT
GPS_KERNNETPUNT
GASWINNING
GELUIDSWERING
GEDENKTEKEN
BOMENRIJ
BOOM
BOTENHELLING
AANLEGSTEIGER
BAAK
WEGWIJZER
WEGAFSLUITING
VERKEERSGELEIDER
VLAMPIJP
VLIEDBERG
ZICHTBAAR_WRAK
WINDMOLENTJE
ZENDMAST
SNELTRAMHALTE
SLUISDEUR
SCHEEPVAARTLICHT
SCHIETBAAN
SEINMAST
TOL
TREINSTATION
STORMVLOEDKERING
STREKDAM_KRIB_GOLFBREKER
STUW
STRANDPAAL
HAVENHOOFD
KLOKKENSTOEL
UITZICHTPUNT
OVERIG
Api Model TNLTerrainLandUse
API Enumeration description of TNLTerrainLandUse
Name Description
AANLEGSTEIGER
AKKERLAND
BEBOUWD_GEBIED
BOOMGAARD
BOOMKWEKERIJ
BOS_GEMENGD_BOS
BOS_GRIEND
BOS_LOOFBOS
BOS_NAALDBOS
DODENAKKER
DODENAKKER_MET_BOS
FRUITKWEKERIJ
GRASLAND
HEIDE
LAADPERRON
BASSALTBLOKKEN
POPULIEREN
SPOORBAANLICHAAM
ZAND
OVERIG
ONBEKEND
API Model description of TNLTerrainLink
id int
priority int
version int
API Model description of TNLTerrainTypeLink
id int
priority int
version int
Api Model TNLWaterFunctie
API Enumeration description of TNLWaterFunctie
Name Description
DRINK_WATER_BEKKEN
HAVEN
NATUURBAD
VLOEIVELD
VISKWEKERIJ
VISTRAP
WATERVAL
WATERZUIVERING
ZWEMBAD
OVERIG
ONBEKEND
Api Model TNLWaterInfrastructuur
API Enumeration description of TNLWaterInfrastructuur
Name Description
VERBINDING
KRUISING
OVERIG
API Model description of TNLWaterLink
appearances TNLWaterVoorkomen[]
id int
infrastructures TNLWaterInfrastructuur[]
mainDrainages TNLHoofdafwatering[]
priority int
version int
waterFunctions TNLWaterFunctie[]
waterTypes TNLWaterType[]
Api Model TNLWaterType
API Enumeration description of TNLWaterType
Name Description
ZEE
WATERLOOP
MEER
SLOOT
DROOGVALLEND
BRON
ONBEKEND
Api Model TNLWaterVoorkomen
API Enumeration description of TNLWaterVoorkomen
Name Description
MET_RIET
OVERIG
API Model description of TerrainGeoLink
id int
priority int
version int
