Api session event editor netcluster set fraction connected
API Endpoint: api/session/event/editornetcluster/set_fraction_connected/
Description: Set Fraction Connected
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Clusters | |
| 1 | OPTIONAL | (Floating point number) | Double |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/", options)
