Api session event editor measure import levees
Revision as of 13:01, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/import_levees/
Description: Import Measure Levee Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Levee Geometries
1 REQUIRED (LEVEE Integer ID or multiple integer values in array [1, 2, 3]) Levee IDs
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Override Angles
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Override Heights
4 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Override relative height
5 OPTIONAL (MEASURE Integer ID) Set for existing Measure ID (optional)
6 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
7 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer (Measure ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_levees/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1, 1.0, 1.0, true ]
Curl example multi item POST
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ true, false, true ] ]
JavaScript example POST
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, 1, 1.0, 1.0, true ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_levees/?crs=3857", options)
