Api session event editor map set height sector
API Endpoint: api/session/event/editormap/set_height_sector/
Description: Update Heightmap Sector Data
| 0 | REQUIRED | (HEIGHT Integer ID) | Height sector ID | |
| 1 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Header: sector widthPoints, columns, rows, baseX, baseY | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Matrix Data Array |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_sector/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_sector/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
body: '[ 1, 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_sector/", options)
