Api session event editor cinematic add keypoint event bundle
Revision as of 13:00, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/add_keypoint_event_bundle/
Description: Add Keypoint Event Bundle
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Datas
1 REQUIRED (Integer number) Integer
2 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundles
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/add_keypoint_event_bundle/", options)
