Api session event editor building import
Revision as of 13:00, 19 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/import/
Description: Import Building Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Building geometries
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Building Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Numeric Attribute Values
4 REQUIRED (FUNCTION Integer ID or multiple integer values in array [1, 2, 3]) Functions
5 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Owners
6 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
7 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/import/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]
JavaScript example POST
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] }, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ] }, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ] } ]}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/import/?crs=3857", options)
