Web 3dtiles tileset
API Endpoint: web/3dtiles/tileset
GET json
API Endpoint: web/3dtiles/tileset.json
Response Content-Type: application/json
Parameters:
Name Location Type Default value
webStakeholderID Header Integer
style Query WebModelStyle WHITE
maptype Query Map Type MAQUETTE
texture Query TextureSize MEDIUM
spacing Query double 2.0
bbox Query String
crs Query String LOCAL
Examples
Basic endpoint:
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKEN
Query for MapType: CURRENT:
https://engine.tygron.com/web/3dtiles/tileset.json?maptype=CURRENT&token=WEB_TOKEN
Model Style: WHITE:
https://engine.tygron.com/web/3dtiles/tileset.json?style=WHITE&token=WEB_TOKEN
Model Style: COLORED:
https://engine.tygron.com/web/3dtiles/tileset.json?style=COLORED&token=WEB_TOKEN
Texture Size (smaller reduces memory): SMALL:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=SMALL&token=WEB_TOKEN
Texture Size (smaller reduces memory): MEDIUM:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=MEDIUM&token=WEB_TOKEN
Texture Size (smaller reduces memory): LARGE:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=LARGE&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 1.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=1.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 2.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=2.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 4.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=4.0&token=WEB_TOKEN
