Web 3dtiles
Revision as of 09:05, 19 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: web/3dtiles/ ===GET json=== API Endpoint: web/3dtiles/tileset.json Response Content-Type: application/json '''Parameters:''' {|class=wikitable !Name !Location !Type !Default value |- | webStakeholderID | Header | Integer | |- | style | Query | WebModelStyle | WHITE |- | maptype | Query | Map Type | MAQUETTE |- | texture | Query | TextureSize | MEDIUM |- | spacing | Query | double | 2.0 |- | bbox | Query | String | |- | crs | Query | String...")
GET json
Parameters:
Name Location Type Default value
webStakeholderID Header Integer
style Query WebModelStyle WHITE
maptype Query Map Type MAQUETTE
texture Query TextureSize MEDIUM
spacing Query double 2.0
bbox Query String
crs Query String LOCAL
Examples
Basic endpoint:
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKEN
Query for MapType: CURRENT:
https://engine.tygron.com/web/3dtiles/tileset.json?maptype=CURRENT&token=WEB_TOKEN
Model Style: WHITE:
https://engine.tygron.com/web/3dtiles/tileset.json?style=WHITE&token=WEB_TOKEN
Model Style: COLORED:
https://engine.tygron.com/web/3dtiles/tileset.json?style=COLORED&token=WEB_TOKEN
Texture Size (smaller reduces memory): SMALL:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=SMALL&token=WEB_TOKEN
Texture Size (smaller reduces memory): MEDIUM:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=MEDIUM&token=WEB_TOKEN
Texture Size (smaller reduces memory): LARGE:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=LARGE&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 1.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=1.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 2.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=2.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 4.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=4.0&token=WEB_TOKEN
