Web
Revision as of 09:05, 19 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: web/ ===GET wms=== API Endpoint: web/wms '''Parameters:''' {|class=wikitable !Name !Location !Type !Default value |- | webStakeholderID | Header | Integer | |- | request | Query | Request | GetCapabilities |- | bbox | Query | String | |- | width | Query | int | 256 |- | height | Query | int | 256 |- | layers | Query | String | |- | layer | Query | String | |- | timeframe | Query | int | 0 |- | crs | Query | String | EPSG:3857 |- | forcexy | Query...")
API Endpoint: web/
GET wms
Parameters:
Name Location Type Default value
webStakeholderID Header Integer
request Query Request GetCapabilities
bbox Query String
width Query int 256
height Query int 256
layers Query String
layer Query String
timeframe Query int 0
crs Query String EPSG:3857
forcexy Query Boolean
maptype Query Map Type MAQUETTE
x Query int -1
y Query int -1
i Query int -1
j Query int -1
bgcolor Query String
format Query String
info_format Query String text/plain
walled Query boolean true
styles Query String
Examples
Basic Endpoint:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&token=WEB_TOKEN
Query for MapType: CURRENT:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&maptype=CURRENT&token=WEB_TOKEN
Query for Grid Style: INTERPOLATED:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=INTERPOLATED&token=WEB_TOKEN
Query for Grid Style: NEAREST:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=NEAREST&token=WEB_TOKEN
Query for Grid Style: ARROW:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=ARROW&token=WEB_TOKEN
Query for Grid Style: COLOR:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=COLOR&token=WEB_TOKEN
Query for Grid Style: FLOAT32:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=FLOAT32&token=WEB_TOKEN
Query for Grid Style: DIFFERENCE:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&styles=DIFFERENCE&token=WEB_TOKEN
GET png
API Endpoint: web/overlay.png
Parameters:
bbox Query String
width Query int 256
id Query Integer -1
format Query String
styles Query String
Examples
Basic Endpoint:
https://engine.tygron.com/web/overlay.png?id=ID&token=WEB_TOKEN
Query with BBOX (EPSG:3857):
https://engine.tygron.com/web/overlay.png?id=ID&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
Query with width=512 and height=512:
https://engine.tygron.com/web/overlay.png?id=ID&width=512&height=512&token=WEB_TOKEN
Query for Timeframe: 0:
https://engine.tygron.com/web/overlay.png?id=ID&timeframe=0&token=WEB_TOKEN
https://engine.tygron.com/web/overlay.png?id=ID&maptype=CURRENT&token=WEB_TOKEN
GET txt
API Endpoint: web/terrain.txt
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
offset Query float 0
worlddatum Query boolean false
decimation Query int 16
Examples
Basic Query:
https://engine.tygron.com/web/terrain.txt?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.txt?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
Query with width=16 and height=16:
https://engine.tygron.com/web/terrain.txt?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.txt?maptype=CURRENT&token=WEB_TOKEN
Query with World instead of CRS Datum:
https://engine.tygron.com/web/terrain.txt?worlddatum=true&token=WEB_TOKEN
GET txt
API Endpoint: web/water.txt
Parameters:
format Path String
id Query Integer
width Query int 256
flipY Query boolean false
Examples
Query Water instead of Terrain elevation:
https://engine.tygron.com/web/water.txt?token=WEB_TOKEN
GET txt
API Endpoint: web/terrain/{z}/{x}/{y}.txt
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.txt:
https://engine.tygron.com/web/terrain/3/2/1.txt?token=WEB_TOKEN
GET tex
API Endpoint: web/terrain.tex
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
Examples
Basic Query:
https://engine.tygron.com/web/terrain.tex?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?worlddatum=true&token=WEB_TOKEN
GET tex
API Endpoint: web/water.tex
Parameters:
format Path String
id Query Integer
width Query int 256
Examples
https://engine.tygron.com/web/water.tex?token=WEB_TOKEN
GET tex
API Endpoint: web/terrain/{z}/{x}/{y}.tex
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.tex:
https://engine.tygron.com/web/terrain/3/2/1.tex?token=WEB_TOKEN
GET bin
API Endpoint: web/terrain.bin
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
Examples
Basic Query:
https://engine.tygron.com/web/terrain.bin?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?worlddatum=true&token=WEB_TOKEN
GET bin
API Endpoint: web/water.bin
Parameters:
format Path String
id Query Integer
width Query int 256
Examples
https://engine.tygron.com/web/water.bin?token=WEB_TOKEN
GET bin
API Endpoint: web/terrain/{z}/{x}/{y}.bin
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.bin:
https://engine.tygron.com/web/terrain/3/2/1.bin?token=WEB_TOKEN
GET html
API Endpoint: web/2dmap.html
Response Content-Type: text/html
Parameters:
base Query WebBaseMap
Examples
2D Map (OpenLayers):
https://engine.tygron.com/web/2dmap.html?token=WEB_TOKEN
GET html
API Endpoint: web/3dmap.html
Parameters:
overlay Query Integer
style Query WebModelStyle
shadow Query Boolean
texture Query TextureSize
spacing Query Double
Examples
3D Map (Cesium):
https://engine.tygron.com/web/3dmap.html?token=WEB_TOKEN
GET geojson
API Endpoint: web/indicators.geojson
Response Content-Type: application/json
Parameters:
Examples
Indicators:
https://engine.tygron.com/web/indicators.geojson?token=WEB_TOKEN
GET geojson
API Endpoint: web/overlays.geojson
Parameters:
Examples
Overlays:
https://engine.tygron.com/web/overlays.geojson?token=WEB_TOKEN
Web Viewer Endpoint (GeoJSON):
https://engine.tygron.com/web/overlays.geojson?&token=WEB_TOKEN
GET geojson
API Endpoint: web/neighborhoods.geojson
Parameters:
Examples
Neighborhoods:
https://engine.tygron.com/web/neighborhoods.geojson?token=WEB_TOKEN
GET geojson
API Endpoint: web/actionmenus.geojson
Parameters:
Examples
Actions:
https://engine.tygron.com/web/actionmenus.geojson?token=WEB_TOKEN
GET geojson
API Endpoint: web/popups.geojson
Parameters:
bbox Query String
Examples
Popups:
https://engine.tygron.com/web/popups.geojson?token=WEB_TOKEN
GET geojson
API Endpoint: web/lines.geojson
Parameters:
bbox Query String
minlength Query Double
maxlength Query Double
type Query Net Type
Examples
Lines:
https://engine.tygron.com/web/lines.geojson?token=WEB_TOKEN
GET geojson
API Endpoint: web/scenarios.geojson
Parameters:
Examples
Scenarios:
https://engine.tygron.com/web/scenarios.geojson?token=WEB_TOKEN
GET html
API Endpoint: web/indicator.html
Parameters:
id Query Integer -1
css Query boolean true
Examples
Web indicator:
https://engine.tygron.com/web/indicator.html?id=ID&token=WEB_TOKEN
GET geojson
API Endpoint: web/actionmenuactions.geojson
Parameters:
id Query Integer -1
Examples
Web actionmenuactions:
https://engine.tygron.com/web/actionmenuactions.geojson?id=ID&token=WEB_TOKEN
GET geojson
API Endpoint: web/measure.geojson
Parameters:
id Query Integer -1
Examples
Web measure:
https://engine.tygron.com/web/measure.geojson?id=ID&id=ID&token=WEB_TOKEN
GET html
API Endpoint: web/popup.html
Parameters:
stakeholderid Query Integer -1
id Query Integer -1
css Query Boolean
Examples
Web popup:
https://engine.tygron.com/web/popup.html?id=ID&token=WEB_TOKEN
