Web terrain
API Endpoint: web/terrain.txt
GET txt
Parameters:
Name Location Type Default value
format Path String
bbox Query String
crs Query String EPSG:3857
id Query Integer
maptype Query Map Type MAQUETTE
width Query int 256
height Query int 256
offset Query float 0
worlddatum Query boolean false
decimation Query int 16
Examples
Basic Query:
https://engine.tygron.com/web/terrain.txt?&token=WEB_TOKEN
Query with BBOX (EPSG:3857):
https://engine.tygron.com/web/terrain.txt?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
Query with width=16 and height=16:
https://engine.tygron.com/web/terrain.txt?width=16&height=16&token=WEB_TOKEN
Query for MapType: CURRENT:
https://engine.tygron.com/web/terrain.txt?maptype=CURRENT&token=WEB_TOKEN
Query with World instead of CRS Datum:
https://engine.tygron.com/web/terrain.txt?worlddatum=true&token=WEB_TOKEN
GET txt
API Endpoint: web/terrain/{z}/{x}/{y}.txt
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.txt:
https://engine.tygron.com/web/terrain/3/2/1.txt?token=WEB_TOKEN
GET tex
API Endpoint: web/terrain.tex
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
Examples
Basic Query:
https://engine.tygron.com/web/terrain.tex?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?worlddatum=true&token=WEB_TOKEN
GET tex
API Endpoint: web/terrain/{z}/{x}/{y}.tex
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.tex:
https://engine.tygron.com/web/terrain/3/2/1.tex?token=WEB_TOKEN
GET bin
API Endpoint: web/terrain.bin
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
Examples
Basic Query:
https://engine.tygron.com/web/terrain.bin?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?worlddatum=true&token=WEB_TOKEN
GET bin
API Endpoint: web/terrain/{z}/{x}/{y}.bin
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
Examples
Query Tiling endpoint: /terrain/{y}/{x}/{y}.bin:
https://engine.tygron.com/web/terrain/3/2/1.bin?token=WEB_TOKEN
