Web water
API Endpoint: web/water.txt
GET water.txt
Parameters:
| Name | Location | Type | Default value |
| format | Path | String | |
| id | Query | Integer | |
| maptype | Query | Map Type | MAQUETTE |
| width | Query | int | 256 |
| height | Query | int | 256 |
| offset | Query | float | 0 |
| flipY | Query | boolean | false |
| worlddatum | Query | boolean | false |
| decimation | Query | int | 16 |
Examples
Query Water instead of Terrain elevation:
https://engine.tygron.com/web/water.txt?token=WEB_TOKENQuery Water instead of Terrain elevation:
https://engine.tygron.com/web/water.tex?token=WEB_TOKENQuery Water instead of Terrain elevation:
https://engine.tygron.com/web/water.bin?token=WEB_TOKENGET water.tex
API Endpoint: web/water.tex
Parameters:
Examples
https://engine.tygron.com/web/water.bin?token=WEB_TOKENGET water.bin
API Endpoint: web/water.bin
Parameters:
Examples
