Api session items chatmessages
Revision as of 08:09, 19 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: /api/session/items/chatmessages/ Edit items with events described at Api session event editor chatmessage. Default Query: <syntaxhighlight lang="text" copy>https://engine.tygron.com/api/session/items/chatmessages/?f=JSON&token=API_TOKEN</syntaxhighlight> Example Response: <syntaxhighlight lang="text" copy>[ { "channelID" : 0, "date" : 1781797226497, "id" : 0, "message" : "Welcome to Team Chat, here you can sent messages to other currently acti...")
Default Query:
Example Response:
  "channelID" : 0,
  "id" : 0,
  "message" : "Welcome to Team Chat, here you can sent messages to other currently active users in your domain.",
  "role" : "INTRO",
  "version" : 1
  "channelID" : 1,
  "id" : 1,
  "message" : "Hello! I am your Tygron Wiki assistant.\n\t\t\n\t\tI can help you with:\n\t\tSearching the Tygron Wiki for information on features, configurations and guides.\n\t\tValidating TQL Queries or API Endpoints to ensure they are correct.\n\t\t\n\t\tHow can I assist you today?",
  "role" : "INTRO",
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/chatmessages/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/chatmessages/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/chatmessages/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/chatmessages/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/chatmessages/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/chatmessages/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/chatmessages/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/chatmessages/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/chatmessages/?f=ZIPSMILE&token=API_TOKEN
Api Model AIChatMessage
API Model description of AIChatMessage
Name Type Description
calcTimeMS long
channelID int Chat Channel ID
date long
id int
message String
role Role
state AIState
thinking String
toolCalls AIToolCall[]
version int
Api Model AIState
API Enumeration description of AIState
Name Description
NONE
QUEUING
GENERATING
FINISHED
Api Model ChatMessage
API Model description of ChatMessage
date long
id int
message String
role Role
version int
Api Model DomainMessage
API Model description of DomainMessage
date long
fullName String
id int
message String
role Role
userName String
version int
Api Model Role
API Enumeration description of Role
Name Description
SYSTEM
INTRO
ASSISTANT
USER
