Api session event editor chatchannel remove
Revision as of 08:07, 19 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorchatchannel/remove/ Description: Remove existing Chat Channel {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Chat Channels | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- | 200 | Boolean (True when at least one item was removed) |- | 300-600 | Codes Overview |} ===Example POST=== Curl e...")
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchatchannel/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorchatchannel/remove/", options)
