Api session event logic measurement set overlays
Revision as of 12:24, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/measurement_set_overlays/
Description: Set base Overlays for an existing Measurement.
0 REQUIRED (MEASUREMENT Integer ID) Measurement ID
1 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlay ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/", options)
