Api session event editor unitdataoverride duplicate
API Endpoint: api/session/event/editorunitdataoverride/duplicate/
Description: Duplicate existing Unit Data Override
| 0 | REQUIRED | (UNIT_DATA_OVERRIDE Integer ID or multiple integer values in array [1, 2, 3]) | Unit Data Overrides |
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorunitdataoverride/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorunitdataoverride/duplicate/", options)
