Api session event editor overlay set visible
Revision as of 12:23, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_visible/
Description: Visualizes or hides an Overlay in the navigation Panel.
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlay ID
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Visualized
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_visible/", options)
