Api session event editor overlay remove legend entry
Revision as of 12:22, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/remove_legend_entry/
Description: Remove the specified legend entries from a specified Overlay. The Overlay must have a custom legend before entries can be removed from it.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Remove from custom difference legend (false removes the entry from the normal custom legend) true or false
2 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Ids of entries which should be removed
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_legend_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_legend_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_legend_entry/", options)
