Api session event editor eventbundle set image
API Endpoint: api/session/event/editoreventbundle/set_image/
Description: Set Image
| 0 | REQUIRED | (EVENT_BUNDLE Integer ID or multiple integer values in array [1, 2, 3]) | Event Bundles | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST
body: '[ 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/set_image/", options)
