Api session event editor eventbundle duplicate
Revision as of 12:21, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoreventbundle/duplicate/
Description: Duplicate existing Event Bundle
0 REQUIRED (EVENT_BUNDLE Integer ID or multiple integer values in array [1, 2, 3]) Event Bundles
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/duplicate/", options)
