Api session event editor actionmenu remove actions
Revision as of 12:20, 17 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoractionmenu/remove_actions/
Description: Remove Actions
0 REQUIRED (ACTION_MENU Integer ID or multiple integer values in array [1, 2, 3]) Action Menus
1 REQUIRED (MapLink or multiple values in array [a, b, c]) Maplink[]
2 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Integer[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SETTINGS", 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "SETTINGS", "ACTION_MENUS", "ADDRESSES" ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, "SETTINGS", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoractionmenu/remove_actions/", options)
