Web terrain
Revision as of 14:56, 15 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: web/terrain.{format} ===GET terrain.{format}=== API Endpoint: web/terrain.{format} '''Parameters:''' {|class=wikitable !Name !Location !Type !Default value |- | format | Path | String | |- | bbox | Query | String | |- | crs | Query | String | EPSG:3857 |- | id | Query | Integer | |- | maptype | Query | Map Type | MAQUETTE |- | width | Query | int | 256 |- | height | Query | int | 256 |- | offset | Query | float | 0 |- | worlddatum | Query | boolean...")
Parameters:
Name Location Type Default value
format Path String
bbox Query String
crs Query String EPSG:3857
id Query Integer
maptype Query Map Type MAQUETTE
width Query int 256
height Query int 256
offset Query float 0
worlddatum Query boolean false
decimation Query int 16
Examples
Basic Query:
https://engine.tygron.com/web/terrain.txt?&token=WEB_TOKEN
Query with BBOX (EPSG:3857):
https://engine.tygron.com/web/terrain.txt?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
Query with width=16 and height=16:
https://engine.tygron.com/web/terrain.txt?width=16&height=16&token=WEB_TOKEN
Query for MapType: CURRENT:
https://engine.tygron.com/web/terrain.txt?maptype=CURRENT&token=WEB_TOKEN
Query with World instead of CRS Datum:
https://engine.tygron.com/web/terrain.txt?worlddatum=true&token=WEB_TOKEN
Basic Query:
https://engine.tygron.com/web/terrain.tex?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.tex?worlddatum=true&token=WEB_TOKEN
Basic Query:
https://engine.tygron.com/web/terrain.bin?&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?width=16&height=16&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?maptype=CURRENT&token=WEB_TOKEN
https://engine.tygron.com/web/terrain.bin?worlddatum=true&token=WEB_TOKEN
