Api session viewers
API Endpoint: api/session/viewers
GET 2dmap.html
API Endpoint: web/2dmap.html
Produces: text/html
Parameters:
| Name | Location | Type | Default value |
| webStakeholderID | Header | Integer | |
| base | Query | WebBaseMap |
Examples
2D Map (OpenLayers):
https://engine.tygron.com/web/2dmap.html?token=WEB_TOKENGET 3dmap.html
API Endpoint: web/3dmap.html
Produces: text/html
Parameters:
| overlay | Query | Integer | |
| base | Query | WebBaseMap | |
| style | Query | WebModelStyle | |
| shadow | Query | Boolean | |
| texture | Query | TextureSize | |
| spacing | Query | Double |
Examples
3D Map (Cesium):
https://engine.tygron.com/web/3dmap.html?token=WEB_TOKENGET tileset.json
API Endpoint: web/3dtiles/tileset.json
Produces: application/json
Parameters:
| style | Query | WebModelStyle | WHITE |
| maptype | Query | Map Type | MAQUETTE |
| texture | Query | TextureSize | MEDIUM |
| spacing | Query | double | 2.0 |
| bbox | Query | String | |
| crs | Query | String | LOCAL |
Examples
3D Tiles (buildings):
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKENBasic endpoint:
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKENQuery for MapType: CURRENT:
https://engine.tygron.com/web/3dtiles/tileset.json?maptype=CURRENT&token=WEB_TOKENModel Style: WHITE:
https://engine.tygron.com/web/3dtiles/tileset.json?style=WHITE&token=WEB_TOKENModel Style: COLORED:
https://engine.tygron.com/web/3dtiles/tileset.json?style=COLORED&token=WEB_TOKENTexture Size (smaller reduces memory): SMALL:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=SMALL&token=WEB_TOKENTexture Size (smaller reduces memory): MEDIUM:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=MEDIUM&token=WEB_TOKENTexture Size (smaller reduces memory): LARGE:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=LARGE&token=WEB_TOKENModel Spacing (larger means e.g. trees further apart): 1.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=1.0&token=WEB_TOKENModel Spacing (larger means e.g. trees further apart): 2.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=2.0&token=WEB_TOKENModel Spacing (larger means e.g. trees further apart): 4.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=4.0&token=WEB_TOKENGET terrain/{z}/{x}/{y}.{format}
API Endpoint: web/terrain/{z}/{x}/{y}.{format}
Parameters:
| format | Path | String | |
| z | Path | int | |
| x | Path | int | |
| y | Path | int | |
| v | Query | String | |
| width | Query | int | 256 |
| height | Query | int | 256 |
| offset | Query | float | 0 |
| worlddatum | Query | boolean | false |
| decimation | Query | int | 16 |
Examples
Terrain Tiles (elevation):
https://engine.tygron.com/web/terrain/3/2/1.bin?token=WEB_TOKENQuery Tiling endpoint: /terrain/{y}/{x}/{y}.txt:
https://engine.tygron.com/web/terrain/3/2/1.txt?token=WEB_TOKENGET wms
API Endpoint: web/wms
Parameters:
| request | Query | Request | GetCapabilities |
| layers | Query | String | |
| layer | Query | String | |
| timeframe | Query | int | 0 |
| crs | Query | String | EPSG:3857 |
| forcexy | Query | Boolean | |
| x | Query | int | -1 |
| y | Query | int | -1 |
| i | Query | int | -1 |
| j | Query | int | -1 |
| bgcolor | Query | String | |
| format | Query | String | |
| info_format | Query | String | text/plain |
| walled | Query | boolean | true |
| styles | Query | String |
Examples
WMS:
https://engine.tygron.com/web/wms?REQUEST=GetCapabilities&token=WEB_TOKENGET indicators.geojson
API Endpoint: web/indicators.geojson
Parameters:
Examples
Indicators:
https://engine.tygron.com/web/indicators.geojson?token=WEB_TOKENGET overlays.geojson
API Endpoint: web/overlays.geojson
Parameters:
Examples
Overlays:
https://engine.tygron.com/web/overlays.geojson?token=WEB_TOKENGET neighborhoods.geojson
API Endpoint: web/neighborhoods.geojson
Parameters:
Examples
Neighborhoods:
https://engine.tygron.com/web/neighborhoods.geojson?token=WEB_TOKENGET actionmenus.geojson
API Endpoint: web/actionmenus.geojson
Parameters:
Examples
Actions:
https://engine.tygron.com/web/actionmenus.geojson?token=WEB_TOKENGET popups.geojson
API Endpoint: web/popups.geojson
Parameters:
Examples
Popups:
https://engine.tygron.com/web/popups.geojson?token=WEB_TOKENGET lines.geojson
API Endpoint: web/lines.geojson
Parameters:
| minlength | Query | Double | |
| maxlength | Query | Double | |
| type | Query | Net Type | |
Examples
Lines:
https://engine.tygron.com/web/lines.geojson?token=WEB_TOKENGET scenarios.geojson
API Endpoint: web/scenarios.geojson
Parameters:
Examples
Scenarios:
https://engine.tygron.com/web/scenarios.geojson?token=WEB_TOKENGET terrain.{format}
API Endpoint: web/terrain.{format}
Parameters:
| id | Query | Integer | |
Examples
Basic Query:
https://engine.tygron.com/web/terrain.txt?&token=WEB_TOKENQuery with BBOX (EPSG:3857):
https://engine.tygron.com/web/terrain.txt?&crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=WEB_TOKENQuery with width=16 and height=16:
https://engine.tygron.com/web/terrain.txt?width=16&height=16&token=WEB_TOKENQuery for MapType: CURRENT:
https://engine.tygron.com/web/terrain.txt?maptype=CURRENT&token=WEB_TOKENQuery with World instead of CRS Datum:
https://engine.tygron.com/web/terrain.txt?worlddatum=true&token=WEB_TOKENGET water.{format}
API Endpoint: web/water.{format}
Parameters:
| flipY | Query | boolean | false |
Examples
Query Water instead of Terrain elevation:
https://engine.tygron.com/web/water.txt?token=WEB_TOKENGET overlay.{format}
API Endpoint: api/session/overlay.{format}
Parameters:
| id | Query | Integer | -1 |
| difference | Query | boolean | false |
| scale | Query | double | 1 |
| value | Query | HeightOperator | |
Examples
IjRff:
https://engine.tygron.com/api/session/overlay.html?id=ID&token=API_TOKENFKphQ:
https://engine.tygron.com/api/session/overlay.html?id=ID&token=API_TOKENWUmz3:
https://engine.tygron.com/api/session/overlay.html?id=ID&token=API_TOKENHeight Map:
https://engine.tygron.com/api/session/overlay.html?id=ID&token=API_TOKENNetwork Overview:
https://engine.tygron.com/api/session/overlay.html?id=ID&token=API_TOKENArea:
