Api session stream
Revision as of 14:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/stream/
GET
Parameters: None
GET export
API Endpoint: api/session/stream/export
Parameters:
Name Location Type Default value
f Query Format BINARY
maplink Query Maplink
id Query Integer
Examples
Export Geo Tiffs ID: 0:
https://engine.tygron.com/api/session/stream/export?mapLink=GEO_TIFFS&id=ID&token=API_TOKEN
Export Geo Tiffs ID: 1:
Export Geo Tiffs ID: 2:
POST import
API Endpoint: api/session/stream/import
Parameters:
id Query Integer
input Query Format BINARY
f Query Format JSON
name Query String
uploader Query String
crs Query String
