Api session event participant measure cancel construction
API Endpoint: api/session/event/participant/measure_cancel_construction/
Description: Cancel a Measure planned by an Stakeholder while in pre-construction phase.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure ID |
| 200 | Integer (Action Log ID) |
curl 'https://engine.tygron.com/api/session/event/participant/measure_cancel_construction/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/participant/measure_cancel_construction/", options)
