Api session event participant attribute action plan
API Endpoint: api/session/event/participant/attribute_action_plan/
Description: Apply an Attribute Action.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (ATTRIBUTE_ACTION Integer ID) Attribute Action ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
3 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute names
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute value arrays
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/attribute_action_plan/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Attribute name 1", [ 1.0, 2.0 ] ]
Curl example multi item POST
[ 1, 1, {
}, [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]
JavaScript example POST
 body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, "Attribute name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/participant/attribute_action_plan/?crs=3857", options)
