Api session event logic undo last building action
Revision as of 12:08, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/undo_last_building_action/
Description: Undo the last Building Action of a Stakeholder.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/undo_last_building_action/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/undo_last_building_action/", options)
