Api session event logic set traffic multiplier
Revision as of 12:08, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/set_traffic_multiplier/
Description: Multiply visual (only) traffic density with this factor.
0 REQUIRED (Floating point number) Factor, default 4.0
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '93'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '75'
JavaScript example POST
 body: '93'
fetch("https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/", options)
