Api session event logic net clusters set load attributes
API Endpoint: api/session/event/logic/net_clusters_set_load_attributes/
Description: Per Net Cluster, for each Net Load of that Net Cluster, set the values of the provided Attributes.
0 REQUIRED (NET_CLUSTER Integer ID or multiple values in array [1, 2, 3]) Net Cluster IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Array with Attribute names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Array with values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array with attribute name 1", [ 1.0, 2.0 ] ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Array with attribute name 1", "Array with attribute name 2", "Array with attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'
JavaScript example POST
 body: '[ 1, "Array with attribute name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_clusters_set_load_attributes/", options)
