Api session event logic net cluster set load attributes
Revision as of 12:08, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/net_cluster_set_load_attributes/
Description: For each Net Load of a Net Cluster, set the values of the provided Attributes.
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Array with Attribute names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Array with values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array with attribute name 1", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Array with attribute name 1", "Array with attribute name 2", "Array with attribute name 3" ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, "Array with attribute name 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/", options)
