Api session event logic net cluster set load attribute
API Endpoint: api/session/event/logic/net_cluster_set_load_attribute/
Description: For each Net Load of a Net Cluster, set the value of the Attribute.
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster ID | |
| 1 | REQUIRED | (String) | Attribute name | |
| 2 | REQUIRED | (Floating point number) | Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute name", 30 ]'JavaScript example POST
body: '[ 1, "Attribute name", 30 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attribute/", options)
