Api session event logic neighborhood set attribute
API Endpoint: api/session/event/logic/neighborhood_set_attribute/
Description: Set an Attribute for a Neighborhood.
0 REQUIRED (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) Neighborhood ID
1 REQUIRED (String) Valid Attribute name
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute value
3 OPTIONAL (true, false) Update Indicators (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/neighborhood_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Valid attribute name", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/neighborhood_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Valid attribute name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, "Valid attribute name", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/neighborhood_set_attribute/", options)
