Api session event logic money transfers set approved
API Endpoint: api/session/event/logic/money_transfers_set_approved/
Description: Approve a Money Transfer
| 0 | REQUIRED | (MONEY_TRANSFER Integer ID) | Money Transfer ID | |
| 1 | REQUIRED | (true, false) | Approved | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/money_transfers_set_approved/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/money_transfers_set_approved/", options)
