Api session event logic global set values
API Endpoint: api/session/event/logic/global_set_values/
Description: Set Global Variable to given number Values.
| 0 | REQUIRED | (GLOBAL Integer ID or multiple values in array [1, 2, 3]) | Global ID | |
| 1 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/global_set_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1.0, 2.0 ] ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/global_set_values/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'JavaScript example POST
body: '[ 1, [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/logic/global_set_values/", options)
