Api session event logic action menu set measure available
API Endpoint: api/session/event/logic/action_menu_set_measure_available/
Description: Add or remove a Measure from a particular Action Menu.
| 0 | REQUIRED | (ACTION_MENU Integer ID) | Action Menu ID | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 2 | REQUIRED | (true, false) | Available | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/action_menu_set_measure_available/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/action_menu_set_measure_available/", options)
