Api session event logic action menu set function available
Revision as of 12:07, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/action_menu_set_function_available/
Description: Add or remove a Function from a particular Action Menu.
0 REQUIRED (ACTION_MENU Integer ID) Action Menu ID
1 REQUIRED (FUNCTION Integer ID) Function ID
2 REQUIRED (true, false) Available true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/action_menu_set_function_available/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/action_menu_set_function_available/", options)
